changing the color of a graph dependent on data?
Is there any way that I could change the color of a sinewave on a graph to correspond to its data collection point? I have an idle state that runs a sinewave graph continuously. I'd like to change the line color of the sine wave at the point in which my program starts collecting data of that particular sine wave. Any thoughts?
Message 1 of 17
(3,886 Views)
You can modify the plot color of a particular plot on your graph using a property node.  Just write the color you want to the Plot.Color property.
Dan
Message 2 of 17
(3,879 Views)
a sample vi with color plot alternating...
Message 3 of 17
(3,872 Views)
I think the OP is asking if you can change a portion of the graph based on a certain time threshold.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 4 of 17
(3,860 Views)
Vt is right, technically. I want the graph to spilt colors at the point of data measurement. Is there another way to see where on the graph I started to collect data?
Message 5 of 17
(3,855 Views)
You could do an XY plot and just change from Plot0 to Plot1 at the transition point.
Message 6 of 17
(3,848 Views)
Would cursors help ?
I added a cursor manually, and using property nodes you can set it to whereever in the time scale. Hope it helps?
Kudos are the best way to say thanks 🙂
Message 7 of 17
(3,842 Views)
mmm, yes. A cursor would work great! How would I consider the time at which my measurements start?
Message 8 of 17
(3,838 Views)
Can you post your VI if you have it ?
If you use a State machine, you could control when your measurements start and set the cursor position accordingly ? Or Like someone suggested, use XY plot for the transition which might look better visually.
Message 9 of 17
(3,833 Views)
it's kind of finicky, but here it is. it starts recording data when the digital input becomes high twice.
Message 10 of 17
(3,819 Views)
