changing text size
Is there any way to change the angle an indicator is displayed at on the front panel of a vi??  Under Numeric Controls> Fill Slide.  I'd like to rotate that slider to a 22 degree, 45 degree etc angle.  I looked at "ctl" info.  That wasn't much help.  I want to replace each of the numbers on the face of a clock w a single slide indicator on a front panel vi.
Clint.
Message 1 of 9
(5,259 Views)
Clint,
no, you cannot rotate controls in the way you request.
I am not sure about the background of your question, but i think that this link might be of interest for you....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(5,253 Views)
You will have to use Edit-->Customize control and modify the control to your liking.
Message 3 of 9
(5,251 Views)
Thanks!  I've been looking at some ( some what similar ) examples in the Discss Grp.  Not exactly what I want but maybe I can modify.  Its the Radar.vi one.  What I wanted to do was a fancy display like the one in a very well known mapping program on the web.  When you submit your request for directions a display popus up to let you know its "LOADING".  There are slider bars in a clock formation that light up as it goes around the circle to let you know the system is busy.  Thats what I was trying to do.  I had a little extra time on a project and I wanted to get a little fancy.  Thought I could try out my LV expertise w a little help.
BTW  The "changing text size" was the wrong subject.
Message 4 of 9
(5,244 Views)
Clint Eastwood wrote:
[...] Its the Radar.vi one. [...]
A link would be helpful for us to see what you are up to.
But talking about Radar, you might be interested in this. (draw radar.vi posted by Troy K.)
Norbert
Norbert
Expert: Geometry
Message 5 of 9
(5,235 Views)
Thats the radar link I spoke of.
Here is a screen cap of what I wanted to do:
Message 6 of 9
(5,220 Views)
This could be an animated gif. Maybe you find one fitting your needs in the internet. But please note that there may be some copyrights on those gifs......
Norbert
Norbert
Expert: Geometry
Message 7 of 9
(5,215 Views)
ok thanks...I'll be careful what I use.
Message 8 of 9
(5,210 Views)
In case you're interested.  I took the Radar.vi that was posted and ( by luck/trial/error) and put in a wait.vi ( 250 msec) inside the timed loop.  Still working it but its VERY close to what I want.  Just need to make the line that rotates a little thicker.
Message 9 of 9
(5,202 Views)
