changing tank color when input from a simulink crosses the threshold
It is not working but you understand my problem correctly
Message 21 of 25
(1,100 Views)
So did you try my suggestion of testing with a local variable?
I recommend that you try it. Post back with the results. Include your LabVIEW code with the post.
If you want to learn how to do this you've got to give it a go yourself, not just ask people to supply all the code for you..... get stuck in!
Message 22 of 25
(1,092 Views)
I cant map a local variable to the simulink using SIT connection. Secondly I dont know how to use local varialble here in labview.
Message 23 of 25
(1,089 Views)
Accepted by topic author Abul Hasan
Deeeep breaths, counting to 10....
Are you actually trying here?  Read the help files, look up examples - you've got to put a bit of effort in.
Do not try to link a local variable to your model.
I have already told you how to create a local variable and I have suggested that you post what you have tried.
As my final attempt to help, pasted below are two options that I suggest you try, one uses a tank control, one uses a tank indicator. I will not post the code for this as I suspect that this is some kind of school project and you should at least be able to create the code for yourself. If you cannot create the code, work through the online tutorials for getting started.
The only difference between the images below and the code already posted, is the use of the local variable.
Message 24 of 25
(1,084 Views)
Thanks a lot to all for helping and providing a solution.
Muhammad Abul Hasan
Message 25 of 25
(1,069 Views)
