changing state of led
Hi, I have a simple program here that I want the LEDs to default to OFF when the program finishes.  I tried using gates to accomplish this, but because of the delays input into the gates, it would throw off all my timing functions.  What can I do so that when the program finishes it will turn off the LEDs?
I'm attaching the code, I'm using 8.2 right now.
Thanks for any help.
(3,108 Views)
Accepted by topic author JJJOndae
Easiest way is to use a local outside of the loop.
(3,095 Views)
PERFECT!!  I don't know why I didn't think of that!  Thank you so much 🙂
(3,092 Views)
Sorry my ignorance, but what are "gates" in this context?
(3,069 Views)
By gates, I meant using the boolean logic gates, such as logic AND, OR, NOR, ect.  But when I had a delay going to one of the inputs, the program originally would wait the entire delay until producing a true or false, when I actually needed a true or false at precise times.  This way however simplifies all that completely.
Message Edited by JJJOndae on 05-23-2010 05:13 PM
(3,056 Views)
You can also use an invoke node and link "Reinitialize to default".
(2,990 Views)
