changing colors depending on output variable
Hi there,
I am pretty new to LabVIEW, using it for my dissertation at university. I looked for similar questions on this and other forums but can't seem to find an answer.
What I'm trying to do is change the color of a graphic depending on the value of another variable. I'm calculating the temperatures inside a gas turbine, and would like to represent the temperature changes graphically for better understanding. So I have output values for different temperatures, which change with mass flow rate of fuel into the engine. How can I make a graphic change it's colors depending on the value of temperature?
Thanks a lot,
Fabian
Message 1 of 8
(3,455 Views)
Do you mean something like this ? Run the VI and change the value of Thermometer.
Message 2 of 8
(3,448 Views)
Hi there,
thanks a lot for your help! Unfortunately, my stingy university can only supply me with LabVIEW 7.1... is there any way you could save it so I can open it in 7.1? :S Is that even possible in LabVIEW?
Again thanks a lot, much appreciated!
Fabian
Message 3 of 8
(3,442 Views)
Here is it after 3 conversions (8.5 --> 8.2 --> 8.0 --> 7.1) !
Message 4 of 8
(3,439 Views)
Wow that's awesome thanks a lot! That's exactly what I need! 😄
Message 5 of 8
(3,435 Views)
I'm happy if I could help you !
Message 6 of 8
(3,429 Views)
Hi JB,
in LV8.5 you can directly save to LV8.0 - this will save you one conversion stepSmiley Wink
Message 7 of 8
(3,422 Views)
Hi Gerd,
Thank you for this hint. There are still enough steps !
Meet you soon on another thread...
Message 8 of 8
(3,419 Views)
