changing color front panel LV 8.2
I want to programmatically change the background color of the front panel.
In LV 7.1 no problem: create reference to front panel and then use a property node to change its color (see attached vi, created with LV7.1, saved in LV8.2).
However when making this from scratch in LV 8.2 the 'color' property for the front panel has dissappeared. Where to find it?
Steven
(2,668 Views)
In LV8.x, the front panel can be divided into several panes, and you can change the color of each pane.
So the way to go now is Panel ref -> Pane ref -> Pane color
Message Edité par chilly charly le 05-06-2007 03:43 AM
Chilly Charly    (aka CC)
(2,650 Views)
ok, makes sense. Should have thought about that myself Smiley Wink
Thanks!
Steven
(2,636 Views)
