changing LabVIEW default icon
I'm creating several LabVIEW library for our project, in that front panel icon has been edited as per the library functions and I want the same Icon to be displayed when I save the file in the folder, because its easy to track or maintain the functions.
Appreciate your help.
Venkateswaran K
(3,737 Views)
Just one thing I want to make it cleared. What exactly you want as the same Icon .llb file?
(3,734 Views)
Thanks for your reply.
I need whatever icon is there in top right corner front panel should be displayed when I save the file. Attached the file for better understanding.
(3,730 Views)
There is no such option available from LabVIEW as well as from Windows (as far I know). If you want to create an Icon you need to have an .exe file there you can have whatever Icon you need.
(3,726 Views)
Thanks for your interest.
Yes I'm aware while building .exe we can use custom icon but i was trying to use custom icon when we save the file itself, it is easy to identify what functions does without read the filename or coding.
ok. we will find someother way to solve.
Venkateswaran K
(3,722 Views)
