change time blinking
Dear:
I need your help. When I build a "vi" I would like to change the time blinking. How can I to change it?
Thanks.
(3,215 Views)
The blinking time is a universal option which can be set from the front panel page of the options menu.
If you are building an executable, you need to copy the appropiate line from the LabVIEW.ini file into your EXE's ini file.
If you only want to do this in one specific place, you can write a VI to replace the blinking property. The VI will accept a reference for the control and a time and will examine the time whenever you call to decide whether it's time to blink the control. The main problem is to define blinking. Not all controls give you the ability to change their colors.
___________________
Try to take over the world!
(3,211 Views)
Thank you my friend. Now is 'ok'.
(3,204 Views)
