change the color of square LED boolean
wow ufaruque123 you solve the problem that I can display 'transparent' by un-check the Decal!
Message 11 of 13
(747 Views)
OK, this is really weird.  I did locate two older LabVIEW versions, LabVIEW 2012 and LabVIEW 2014.  I tried putting a square LED on both, and making it Transparent.  When I did this, it seemed to turn Transparent and then back to Dark Green, so I changed it again to transparent and it stayed Transparent.  When I tried to repeat this, it stayed Transparent.  I must confess "I don't get it", but the word "Bug!" (and maybe "This sounds familiar ...") are rattling around in my head.
I'll repeat my advice -- find a newer version of LabVIEW (see a friend or colleague) and open your program with the newer version.  Replace the Square LED and see if the new one's Properties are any better.  I'll report back if I find out more ...
Message 12 of 13
(746 Views)
Congratulations to ufaruque123 (and good timing -- I was about to call this in to NI and say "Hey, what's going on here?") -- saved me from embarrassing myself.
Message 13 of 13
(741 Views)
