change the color of a bar indicator depending of the numeric value
I am trying to customize a numeric indicator, a tank bar, to change the color of the bar depending on numeric value.
I supposed that I could to make it by creating a property node for change FG and BG, connected to both color box inside a case structure, but when I get it run returns a message of wrong.
does someone know how to customize it?
(4,147 Views)
Accepted by topic author Paul Moabdi
You need to use the property 'Fill Color'.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,142 Views)
I almost became crazy for solving it and was so easy. I going to upload the vi that I made as example. Only a question. is possible to change the blinking colour to another different from yellow?
Thank you very much for the help.
(4,125 Views)
You can change the blink color by going to the Tools >> Options menu in LabVIEW and the environment section.  Unfortunately, this is a LabVIEW wide setting and you can't create different blink colors for different controls.
(4,109 Views)
