change short cut menu of a graph dynamically
Can I change the run-time short cut menu of a graph from a menu (*.rtm) file dynamically?
Thanks.
XL
(1,312 Views)
I don't know.
An x control would let you do it but there are probably easier ways.
What have you tried so far?
"Should be" isn't "Is" -Jay
(1,280 Views)
Thanks.
XL
Yes you can!!!!
There is even a shipping example
While it seams a bit obscure to see exactly how to obtain a reference to a specific control's menu without an event node once you obtain the reference the menu manipulation is straight forward
(1,262 Views)
