Amit,
Use property nodes. Right click on the control, and choose "Create Property Node". Select Range, All Values to get a cluster of the max and min. Be sure it is set to Write Value. Then, use this cluster in a Bundle to input the values when and where you want.
Look in the examples for similar, and in the examples and documentation for using property nodes and references.
