change min/max of one y-axis programmatically
I have a graph/chart with left and right y-axis.
How do I programmatically change the min/max (range) of ONLY the right axis?
I look in the property node, see Y-axis, but I am not sure which axis( left or right).
(3,191 Views)
to choose which scale you want to change you must specify the "Active Y Scale" property first. And only after this you can change elements in "Y Scale->Range" properties. By default "Active Y Scale" is equal to 0 and corresponds to the first created y scale.
See example for more details.
Good luck.
Oleg Chutko.
(3,191 Views)
