change information in the header
Hi Labview users,
I collect data with a DAQ and store it in binary files just like in the ContAcq&GraphVoltage. There is a 'create header.vi' there which add to the binary file information about time and about the scaling parameters. You all must have seen how a file like this (and in particular  the header) looks like after conversion to text:
waveform    [0]    [1]    [2]
t0    1/1/1904  02:00:00.    1/1/1904  02:00:00.    1/1/1904  02:00:00.
delta t    0.000100    0.000100    0.000100
time    Y[0]    Y[1]    Y[2]
1/1/1904  02:00:00.    6.945491E-1    8.289447E-1    8.544058E-1
1/1/1904  02:00:00.    6.939045E-1    8.295893E-1    8.589178E-1
1/1/1904  02:00:00.    6.932599E-1    8.289447E-1    8.634299E-1
1/1/1904  02:00:00.    6.942268E-1    8.289447E-1    8.614962E-1
1/1/1904  02:00:00.    6.945491E-1    8.295893E-1    8.582733E-1
1/1/1904  02:00:00.    6.945491E-1    8.308785E-1    8.660083E-1
There are 2 questions I am dwelling on:
1.  The first column does never change regardless the files regardless the date of the recordings. I suppose it should be the date but it;s always the same. The second column which corresponds to the clock(hour'minute'second) always starts from 02:00:00. Why not 00:00:00?
2. I would like to have the clock format only in miliseconds. First, it is more manageable , second, with the current format, Matlab has problems in separating data columns.
Do you have some solutions for me? I would very appreciate that.
Thank you in advance,
Dana
(2,507 Views)
(2,478 Views)
