change from listbox into multicolumn listbox
Hi everybody,
I need your help. I made myself with help from this forum an algorithm, to have only selected plots visible in the chart. Now I want to change the listbox into a multicolumn listbox. So that it is possible to display only those graphs that are selected. I have tried to implement an doubleclick property, but it did not work. Most probably the problem lies in the disable indexing, which is greyed out, if I connect the multicolumn listbox.
Does anybody have an idea?
Thanks in advance!!!
(2,652 Views)
Change seletion mode of listbox2 to "0 or more items". Now you can select as many items as you want (try e.g. ctrl+click)  and graph the corresponding plots accordingly.
(2,642 Views)
Thanks alot, it works perfectly.
Great forum!!
(2,629 Views)
