change data
Hi all
I 'd a Boolean Variable change always, I am trying to hold the zero untill the next zero come, ( like if it is 0 and change to 1 no problem but if it is 1 and change to 0 and change to 1 again I wanna keep 0 untill the 1 finishe or or untill the next 0 come)
thank you for your help .
(3,510 Views)
Sorry, I am not real clear on all of this.
As I understand 0->1 transition, fine.
1-> 0 transition, fine but hold until the 0 happens again....then what?  Additionally, you stated that after the 1 is completed, then transition.  I am not clear on this part.  Can you please explain a little better, provide sample code or a picture of what is going on?
Paul
(3,500 Views)
ok
I am doing a small test for encoder, with a motor and the motor control is DLL file I use the Call Library Function to run it  but the problem I wanna swap the speed (or the direction) every time.
I dont have anything tell me the motor stop unless the Data from the encoder when the data stop changing in the text box that is mean the motor stop I wanna swap the direction in that case I have to hold the zero untill the next stop.
(3,498 Views)
thank you for helping me
(3,497 Views)
sorry the texsting of the Data change it is boolean
(3,494 Views)
