change color of background text when blinking
Hello ,
I want to blink a text in White with background in Black.
I use Property Node but a always have a Red Color when blinking ,why ??
regard
mike
Message 1 of 9
(3,921 Views)
Do you only want the text to blink?
Tim
GHSP
Message 2 of 9
(3,917 Views)
Unfortunately the blink background is a fixed Environment option in LV.  You'll have to roll your own.
Message 3 of 9
(3,916 Views)
yes only the text blinking.
Message 4 of 9
(3,906 Views)
Actually tou can change it Options > Environmet > Blink foreground and blink background BUT it only applies to new vi's.  You can't change it after the vi is first opened and you can really mess with co-developers heads by using a non-default setting.:womanmad:
You can access the controls property text>colors and use a loop to get a pseudo blink effect.
"Should be" isn't "Is" -Jay
Message 5 of 9
(3,900 Views)
Here is how I would do it. You will have to make it fit your code. I would probably put it outside of the main loop and use events to tell it when to blink. You could use a reference to the control that you want to blink. It reall depends on how your program works and what is easier for you.
Tim
GHSP
Message 6 of 9
(3,893 Views)
Thanks aeastet Smiley Happy
I think It's the right solution.
Tanks a lot
Mike
Message 7 of 9
(3,874 Views)
Then you should make it as the solution so that everyone knows that your problem is solved.
Tim
GHSP
Message 8 of 9
(3,861 Views)
With this you can cause any property to 'blink' between any two values.
Message 9 of 9
(3,831 Views)
