change between cases
i have this vi diode-transistor. it should change from diode to transistor and back with the enum on the front panel.i ve looked in the forum for other people having the same problem and did what i found but nothing worked.  please take a look if you have the time and tell me what you think. thanks in advance
(3,319 Views)
Hey,
Please have a look at the statemachine or producer/consumer design patterns, I think this could help you.
You will need to place the enum inside a loop. In your code it will be read once, just at the start of your VI.
Christian
(3,312 Views)
I don't understand the question...
Jim
(3,292 Views)
Hi thess,
you used a RING and not an ENUM. They are NOT the same!
Anyway: you already wired it up. Where did you have problems exactly?
I would only remove those locals on the right side, just use wires from their terminals...
Additional note: I couldn't read a lot of your labels. What language settings are you using?
(3,274 Views)
i am from greece that's why. my labels are in greek. thanks for taking the time to have a look at it though. i just opened my pc again so i ll spend some time to look at it again and get back to you. thanks ag...
(3,256 Views)
