change background color of indicator
OK, so I am back onto this again.  This example changes the color of the background or text in every array element.  Can you change the background of a string indicator in just one array element?
Basically, I want "String 1" background in Array element 1 to be a different color than "String 1" background in the rest of the array elements.
Message 11 of 12
(916 Views)
No this cannot be done. All elements in the array share the same properties. If you try to change the color of "String1" in one element ALL "String1" in the array will change.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
Message 12 of 12
(908 Views)
