change background color for entire table
Using the property node of a table, how do you change the background color for the entire table?
Thanks.
(4,540 Views)
Accepted by topic author QRP
Check out the advanced help of the "ActiveCell" property:
The following table lists example values for this property.
RowColumnResult
–2 0 Selects all cells of the first column, including the column header.
–2 –2 Selects all rows and columns, including column headers.
–1 0 Selects the header of the first column.
–1 –2 Selects the headers of all columns.
Set the ActiveCell to -2,-2 then set the activecell -> cell background color
Is that what you are looking for?
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(4,523 Views)
Yep that worked great! Is there a way to turn off the selection within a table. I'm just using it for status only.
Thanks again.
(4,518 Views)
Are you using a table, or a multi-column list box?  By selection, do you mean a highlighted row?  If so, then I think you're using a multi-column listbox and you might be better off using a table indicator.  If I'm right, but you still want to use the multi-column listbox, try setting the Disabled property to 1 (Disabled).
(4,512 Views)
Try setting the "Disabled" property to "Disabled" or "Disabled and Greyed Out". Be mindful of the end user, they might like having the ability to select and copy/paste out of the table.
Charles Chickering
(4,509 Views)
Good point. Thanks a lot for your help.
(4,506 Views)
