change a numeric control value from any sub VI
HI!
Is it possible to change the value of a numeric control (or a boolean) in a VI that is not called by the VI where the value should be taken of.
Usually if I want to change a value on the calling VI by a SubVI I pass a reference of that control to the SubVI.
What I want to do somehow is a reference to a VI and from there to a control and change the value of that control. Is that possible? How?
ANDY
(3,830 Views)
Yes it's possible and you do it like you said - get a reference to the VI. Then you use the method (an Invoke Node) Set Control Value or Set Control Value [Variant]. With both, you have to specify the control name. With the first method, you have to flatten the data. With the second, you just have to wire the value.
(3,824 Views)
One method is to open the vi using vi server
find the control reference using the vi reference
and wire in the value.
here is an example I created.
Champion CLA
Making senseless computers do
intelligent real world things
is NOT easy. SO MAKE IT FUN!
(3,818 Views)
Thanks for the answers.
I think the picture is from LV 7.x ?
I only have the version without variant in LV 6.1.
Can you post a picture of how it works with the flatten date thing?
ANDY
(3,805 Views)
Here's how you do it with the Set Contro Value method. The function used is Flatten to String.
(3,792 Views)
Thanks very much.
It works
ANDY
(3,782 Views)
