change Chart background color during runtime
I want to change the background color of my chart during runtime.
I can set and read-out the color with a property node but the apperance on the frontpanel is not changing.
After stopping the VI the chart suddenly gets updated.
Please check my VI attached.
Do someone knows a workaround?
(3,377 Views)
Hi Robert,
that seems to be a limitation of the graph with this very property as I see the same problem using LV2011.
Setting the plot area background color works instantly…
(3,363 Views)
Hi GerdW
thank you for the reply.
I have tried with LV2011SP1 and LV2013SP1. It dosn't work in both versions.
Is there a change to fix this problem?
Best Regards
Robert
(3,313 Views)
Hi Robert,
to "fix" the problem you can make the chart transparent and put it in front of a second indicator. (like a simple bool switch). Then change the color of that switch…
(3,303 Views)
Hello Robert,
another option would be to place (for example) a vertical smooth box behind the chart and change the color of it.
See my attachment.
Best regards
(3,238 Views)
