change 1D array of 32 bit integer to 1D array of BV tag
i just want to change 1D array of 32 bit data type to 1D array of BV tag to display this in Historical trend viewer
an urgent reply wud b highly appreciable
VINO
(3,015 Views)
What you are asking for is not really clear for me... I assume you want your array of numeric values to be replaced by a boolean array.
Also, I was not sure about what numeric value has to correspond with TRUE or FALSE...
Here is a possibility to do this :
I hope this will help you...
Message Edité par TiTou le 03-29-200609:07 AM
Epictetus
Antoine Chalons
(3,018 Views)
You will have to write each array value to a unique tag name if you want multiple tags in the historical trend. Wire the I32 array and a tagname array into a for loop with indexing enabled on each tunnel. You will need to convert the I32 into a DBL, the Write tag vi wants a DBL for an analog input. If you don't want it as individual tag values, let us know.
(3,006 Views)
Hello Titou,
why do you use a For loop? Your example will work without!
(3,004 Views)
That's true GerdW,
I always forget and relearn that more and more functions are polymorphic ;)...
nh, this will work the same as the previous I posted :
Message Edité par TiTou le 03-29-200612:24 PM
Epictetus
Antoine Chalons
(3,000 Views)
