certification: Examity environment problem, no keyboard
Hello all.
I tried to pass two times CLA, last month, + yersteday.
At every attempt, once inside the exam VM, I experienced technical keyboard problem: I simply cannot use it.
The evident consequence is that I cannot neither name my project elements, nore document my code, that severely compromises my attempts
Before, I passed OK the compatibility check required by the Examity platform (see joined the screenshot). and I tried the CLA 3 years ago with the same computer (PSIexams platform) with no problem.
The problem appears from the very begining of the session opening. the examinators are unable to explain the cause. I have no clue about what is happening.
Have you experienced such problem?
thanks in advance for your feedback.
->joined: Examity compatibility check, laptop system properties
->I'm using a laptop,
->connected to Ethernet.
->Integrated keyboard (no additional), working OK outside the VM and working OK inside the CLED exam part-1 that I passed 3 weeks ago (MCQ type, no VM)
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
Message 1 of 1
(916 Views)
