censored parts
Hi
I need to implement a lock-in amplifier as part of a graduation project .(using PXI)
As a first step, i want to build a vi containing some of the lock-in common features, with  a few extra ones.
i've downloaded the lock-in startup kit and tried to use some of the vi's like the pll or demodulator but all i see is a big "censored" on
the front panel.
how can i use these sub vi's (or any other relevant) in my vi?
important note: my goal for right now is only to simulate the functionality of the lock-in, no DAQ or external hardware required.
thanx!
(3,227 Views)
You simply use them as subVIs.
The context help describes the functionality and connectors. Also observe how they are used in the included demos. A passworded VI can be used like any other subVI, it simply cannot be edited and inspected.
(3,200 Views)
The lock-in amplifier is basically a synchronous demodulator followed by a low-pass filter. A synchronous demodulator is made simply by multiplying your reference signal with your measured signal (caused by the reference signal). You multiply sample by sample, with the standard multiply function. A low-pass filter is also easy in Labview. A PLL can also be built in Labview. But I have never done it myself. But I have made a lot of synchronous demodulators. It is a toolkit called "NI Modulation Toolkit " I think this toolkit have PLL. Some Googling will give a lot of help. But I have also included some documents. You will also find a funny document here
http://www.cpm.uncc.edu/programs/LIA_Primer.pdf to big to send
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,165 Views)
Another reason could of course be, that NI have used some X-rated controls/indicators in this application. So instead of risking a lawsuit they choosed to censor some material. Who knows because I have never seen this kind of censorship in Labview before
(3,147 Views)
