cdaq9184 calibration
Hello, I simply have a DAQ assistant in my VI, and I want my channel to be calibrated :
In NI-MAX I have created a task but my channel is not updated in the VI. Is there a block i've forgotten ? Or the channel might be updated ?
(3,114 Views)
Accepted by topic author Reg_edit
Hi Reg,
does your DAQAssistent use this task created in MAX?
You know you can use plain DAQmx functions? Most of the time it's very easy (and less painful than the DAQAssistent tends to be)…
(3,087 Views)
Yes, my task has been created in MAX. I just saw a tab in the DAQ assistant which is called Calibrate, does it modifying the value by calibrating from the task in MAX ?
(3,045 Views)
