cases programmatically from xml in case structure
I want the cases in my case structure to be updated programmatically from an xml file. Is this possible?
Message 1 of 12
(5,318 Views)
This is only possible in the IDE when the vi with the case structure is not running. You can use VI scripting to programatically create the cases.
Felix
Message 2 of 12
(5,312 Views)
I want to create a service of this vi. So when it reads the xml it need to update its case structure.
Message 3 of 12
(5,309 Views)
You can, but don't forget what Felix wrote - a VI can't programmatically change itself.  You'll need a separate VI to modify the Case Structure you're working with.
This example gets a reference to the target VI, traverses for all Case Structures, selects the target by its label, adds a frame and gives it a Selector Label.  You'll need to modify the last three VI Server nodes to accommodate your particular application.
Good luck.
<edit> take a look at my CaseSelect JKI RCF Plugin, it contains a bunch of Case Structure manipulation code.</edit>
Jim
Message 4 of 12
(5,307 Views)
Are you planning to programmatically add code inside the new frames from information in the XML file?
JKI's award winning EasyXML Toolkit can help you process your XML files.
Jim
Message 5 of 12
(5,291 Views)
Depending on what you are trying to do, it may be easier to replace the case structure with a LabVOOP command VI (see command pattern here).  This will allow you to dynamically add code as well as "cases."
What problem are you trying to solve?
Message 6 of 12
(5,262 Views)
It's not realy a problem. It's more an implementation. I have a config file in XML and I want a process configure it's ID's along this XML structure.
Message 7 of 12
(5,253 Views)
Are you changing just the IDs or also the code which executes for each ID?
Message 8 of 12
(5,243 Views)
the code also....
Message 9 of 12
(5,228 Views)
Then you do want a command pattern.  You have a couple of options.
  1. Use the LabVOOP command pattern linked above.  This probably the easiest way to do it.
  2. Instead of having a case structure, call a subVI dynamically using VI server.  The subVI selection is made based on the "case" you want to execute.  This is a manual version of option 1 and is the old school way we would have used before LabVOOP was created.
Note that in both cases you can use a subpanel to host a UI for each new plug-in.  This works quite well.  Let us know if you need more information.
Message 10 of 12
(5,191 Views)
