case
I have a Vertical toggle switch and a led
if the led is true and a switch is false then
 if i turn on a switch then turn off the switch then the led will be false
how can i do this?
Message 1 of 9
(4,732 Views)
What happens when the LED is FALSE?
Message 2 of 9
(4,693 Views)
nothing
Message 3 of 9
(4,626 Views)
nothing
Message 4 of 9
(4,626 Views)
nothing happens
Message 5 of 9
(4,677 Views)
Kudos to your Instructor who designed this problem.  Have you learned about Shift Registers and While Loops with the Stop Indicator having the constant True wired to it?  [That's a hint, by the way ...].
BS
Message 6 of 9
(4,639 Views)
Hi progandroll,
What happens when you use a horizontal toggle switch?
No, that's no hint. 😄
Message 7 of 9
(4,618 Views)
Why would you hint that he should wire a true constant to the conditional terminal?  This certainly doesn't sound like an embedded application.  Wire the stop control so you're not forced to use the abort and learn a bad practice from the start.
Message 8 of 9
(4,602 Views)
I would use an Event Structure to react to the change in values of your switch.  You should store your LED's value in a shift register.  You don't event need a case structure.  Use a Select function to choose what the value of your LED should be.  I'll leave the actual logic inside of the event case to you.
Message 9 of 9
(4,578 Views)
