case structure
I updated the program with the suggestions. But the program runs only for one iteration of image acquisition and stops.
Message 11 of 14
(797 Views)
Hi ymadhuri,
your VI runs only once because there's no loop in the block diagram...
When suggesting just one frame of a flat sequence I thought of something like that:
Message 12 of 14
(789 Views)
I corrected the code and when I run the code i do not observe my expected result. Is this code corrct to achieve the below mentioned task.
When I execute the program, want to acquire real time images and display on the front panel. When the user press the save boolean swith then the image   should be sent for pattern matching. If the mattern is matched then a green LED should turn on and the matched pattern should go to "speak text "vi to give audio output. If the pattern is not matched then a red LED should glow.
Message 13 of 14
(769 Views)
Any suggestions to proceed further?
Message 14 of 14
(725 Views)
