case structure
Dear all,
I have the a sequence structure needled into a case structure needled into another sequence structure. You can see the figure I attached. Is there a simple and quick way to add the cases of the sequence structure inside to the sequence structure outside? About the case structure I can either delete it either copy it inside all the cases of the resulting sequence structure.
Thanks for the support
(2,904 Views)
I really don't understand what you are asking here.
But looking at your screenshot with where you have a 40 frame stacked sequence structure and also a 5-frame, it looks like you've already started down the wrong path with your program architecture.
Search the forums and LabVIEW examples for "state machine".
(2,893 Views)
That program will be a hard and valuable lesson to fix. 🙂
Sub vi's and state machines are your friend.
I guess there's also some code copies in the frames?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,885 Views)
You have received good advice about state machines.
Although it may not work (depending on how the rest of the code is written), you can replace the sequence stuctures with case structures. Certainly things like sequence locals will leave you with a lot of broken wires.  Then gradually combine the case structures into one for the state machine.  You might be better off developing a state machine from the Desing Patterns or Examples.
Lynn
(2,871 Views)
