case structure language help
gchristi1 wrote:
I use comparisons, then convert boolean to integers and add creating three cases, 0, 1, 2
I'm still learning, so there may be a better solution.
I tried
..0.0
0.0
0.0..
and crashed LabVIEW 8.5 both times I tried it.
OK, LabVIEW should never crash, no matter what you do.
Can you reproduce exactly what you did to crash labview reproducibly? NI should be made aware of it so it can be fixed.
Easiest would be if you could save the VI right before the crash, attach it here, and then tell us what to do to crash it. Thanks!
Message 11 of 13
(771 Views)
Hi Tim,
I've modified that example VI slightly to count the number of iterations for each case. Then the code subtracts the start time from the end time and divides it by total number of iterations to give you the time per iteration.
You could go on to multiply that time by each iteration counter to find the number of time spent in each case.
Hope this is of use
Regards
Steve
Message 12 of 13
(763 Views)
Please note that the business of counting (along with several examples) has been moved here.
Message 13 of 13
(756 Views)
