case structure label changing
I have a case structure that I wanted to change the name of and delete one.  I did this on the case structure pane and the new name turned red.  This is probably due to the enum connected to the case selector still has all the old enum labels.
i have tried to edit the enum but it will not allow me to change the enum name and will not delete the case structure that I deleted.
How do I get the enum that is connected to the case structure selector to match the case structures?
metzler CLAD
(6,003 Views)
Accepted by topic author metzler
I figured it out, I changed the type definition and the changes took.
Sorry to waste your time.
metzler CLAD
(6,000 Views)
You should never alter the case names manually!
Since they are in an enum, the names come from there.
By default there are only two cases in a case structure. If you need more because your enum has more items then, right click the case and select "Add case for every value" (or something like that 🙂 ). Cases will be automatically added.
Hop this is an answer to your question!
(5,997 Views)
