cara mengontrol kecepatan motor dc dengan labview berbasis fuzzy logic
Izin bertanya master labview yang ada disini, cara mengontrol kecepatan motor dc dengan labview berbasis fuzzy logic bagaimana ya ? soalnya saya sudah mengikuti example yang ada di labview yaitu fuel tank.vi kendalanya masih bingung agar diterapkan untuk kontrol kecepatan motor dc. Terimakasih sebelumnya
(3,018 Views)
Hi Rivaldo,
@Rivaldo733 wrote:
Permission to ask the master labview that is here, how to control the speed of a dc motor with labview based on fuzzy logic, what should I do? the problem is I have followed the example in the labview, which is the fuel tank. vi, the problem is still confused to be applied to control the speed of a dc motor. Thank you in advance
1st: you should write in English as this an English speaking forum!
2nd: how is the FuelTank example related to any "motor speed control based on fuzzy logic"?
You should do:
  1. Learn LabVIEW.
  2. Learn about fuzzy control and its implementation in LabVIEW.
  3. Apply your knowledge to solve your requirements…
(2,977 Views)
Hello mr, I want ask about how to change gain porpotional motor speed control close loop become fuzzy logic in labview ? I uploaded a motor speed control image that has not been changed to fuzzy logic.
(2,981 Views)
Hi Rivaldo,
did you use the last 4 days to take the steps mentioned in my first message?
What is the result of learning about Fuzzy control in LabVIEW?
(2,931 Views)
