captions
I was wondering if possible to write to a caption while vi running?  Asking because thought convenient way to save/change comm commands associated with that object.   Thankyou
Message 1 of 16
(5,697 Views)
Yes, it is possible. Use a property node set to write the Caption.Text property:
Message 2 of 16
(5,687 Views)
What does writing a caption have to do with save/change and objects? Please clarify your question.
Message 3 of 16
(5,684 Views)
Thankyou HopeH    I did try that but i could not write directly to the caption - only to a text box that then wrote to the caption.  There are workarounds but was just hoping to keep simple.
Message 4 of 16
(5,674 Views)
Hi Sir
this vi has controls i want user to be able to define commands to a plc  I would typically have an user edit list that i would save to a file with controls associated with new commands.  I though this caption method would be a simpler way to go    Program would just read the captions and send that command.  hope this not confusing.
Message 5 of 16
(5,671 Views)
Seems way more complicated! 😮
Message 6 of 16
(5,667 Views)
Just started it - Seemed easy enuf up to this pt. Visually i like it  but as you say - may prove more difficult.
Message 7 of 16
(5,655 Views)
What do you mean when you say you can't "write directly to the caption"? I don't understand why you would have to write to a text box (by text box, do you mean string control/indicator?) first. Just wire whatever string you want into the property node.
Message 8 of 16
(5,638 Views)
Hi HopeH    I want to write to it while in run mode(its for the user )
Message 9 of 16
(5,636 Views)
Maybe I am misunderstanding what you mean? Just changing the caption while in run mode is very simple. Here is an example. Is this what you mean, or something else?
Message 10 of 16
(5,631 Views)
