cant open labview
i need administrator rights to open labview and i dont have them what can i do? im on a mac
(2,887 Views)
Exactly what happens when you try to open LV? I run LV on a Mac without administrator rights. You may need to have read and write permission in some folders in the Applications:National Instruments:LabVIEW folder because LV may write to some files there, although most things are saved in the user dierectory.
What version of LabVIEW? Which OS version and what hardware (PPC or Intel)?
Lynn
Using LV on Macintosh since version 1.2
(2,875 Views)
Hi
Like Lynn asked what exactly happens when you attempt to open LabVIEW, you should not require administrative priviledges to just use LabVIEW. If you could answer Lynn's questions about what versions of LabVIEW, MAC OS and if any types of hardware you are using, it will help towards resolving this issue as quick as possible.
Kindest Regards
YatinM
NIUK & Ireland
(2,849 Views)
