cannot run debugger for startup.exe
I'm trying to run the debugger for my startup.exe.  The main VI deploys and runs from the Project Explorer, except it looses communication with the Target while the Ballard cards are being configured (SR #7761927).  It encounters this problem about four times (apparently one for each card) before completing deployment and running.  It takes a few minutes to complete.  I know it is running because the VI front panel has an LED indicator that blinks when it is running.
When I run Operate->Debug Application or Shared Library and give it the IP address of the PXIe I get the following error "Failed to lookup debuggable applications or shared libraries." I have checked the "Enable debugging" box in the Advanced page of the Application Builder.  I wait at least 5 minutes before attempting to run the debugger.  Is my debug problem due to the loss of communication?
Message 1 of 1
(2,022 Views)
