cannot mimimize window programmatically
I just discovered a "feature" of LabVIEW (2015, if it matters) that I'm not sure is one with which I agree.
I found that I cannot programmactically minimize a VI's front panel window if:
     VI Properties --> Window Appearance --> Custom --> Allow user to minimize window        box is not checked.
I guess I prefer to draw a distinction between what the programmer is allowed to do versus what the programmer wants to allow the user to do.   Is this an unreasonable request?
(4,963 Views)
Accepted by topic author WNM
You know, I didn't believe what you said, but wrote a little LabVIEW demo (in 2015) and proved it to myself.  But that also gave me the "fix".  Before trying to minimize the window (which I presume you are doing by the Invoke Node FP.Open, State = Minimized), get the FP.Minimizable Property and then set the FP.Minimizable Property to True.  Now you can Minimize, and subsequently bring it back by calling FP.Open with default inputs, following which you again set FP.Minimizable to the original value you got from the first "Get".
Note that this works whether or not the VI has "Allow User to Minimize" set or not.  Of course, if it is not set, then all the calls to FP.Minimizable aren't needed ...
(4,932 Views)
Yep.  I came to the same conclusion and the same fix, though using a subVI that does it all on behalf of the calling VI.  I've attached that subVI (saved to 2011) on the off chance that someone else might find it useful.  Thanks for the confirmation of the "feature".
(4,882 Views)
