12-07-2009 07:02 PM
We got a Bruker EMX plus EPR instruments. They are using network card controlling all of the instruments. I wish to write my own program using LabVIEW. However, when I try MAX (ver 4.6.1) to look for network devices, nothing was found.
The program (not by LabVIEW) by Bruker works well.
NI-DAQmx 9.02 was installed.
Thanks.
WT
12-07-2009 07:23 PM
How exactly are you trying to find it in MAX? MAX will autodetect VXI-11 and LXI devices. Is your instrument compliant with either? Have you tried entering the IP of the instrument manually?
p.s. What does DAQmx have to do with anything?
12-07-2009 08:10 PM
Thanks.
What is VXI-ii/LXI devices? I only know the instruments are connected to the computer through a network wire and network card. I did try entering the IP of the instrument manually, see attached screen shot.
I am sorry I cannot catch the meaning of "What does DAQmx have to do with anything?"
Best,
Wei Tong
12-07-2009 09:35 PM
12-07-2009 10:02 PM
I thought it was like GPIB devices or serial/com port devices. When I have this interface(GPIB controller,network controller, etc..) driver installed, then MAX suppose to find them.
OK, I see.
03-24-2010 12:41 PM
Hi Weitong
I am using the Bruker Field controller only and not using any other EPR devices. My purpose is to control the mass spectrometer (indigenously built) magnet. This Bruker controller can be connected to PC using ethernet (rather cross-over) cable. The software provided by Bruker works very well. However, as a part of major program, I must talk to Bruker controller through LabView. Interestingly, this controller does not have IP address and the Bruker software smartly detects it! Do you have any idea how to talk with this controller using MAX?
03-25-2010 06:10 PM
Do you have the manual for the Bruker Field controller you referenced? If there is a way to interact with it programmatically, it should be mentioned in there.
It does not look like we offer any instrument drivers for Bruker hardware on ni.com/idnet.
thanks!@
03-26-2010 10:01 AM
03-29-2010 11:09 AM
I had talk with bruker technician. according to him the field controller is not having any ip address and their new software just recognize the unit. But i feel it should have an address. When I ping the ip address (momentarily shown when the bruker software launches and start talking with field controller). The ping result is positive. So, I think i was wrong, this device has a ip address which is 192.168.1.104
Does this help labview to talk with this device?
03-29-2010 11:18 AM
