cannot build executable
When I try to build an executable I get an error saying a vi is not executable when in fact it is working fine. Sometimes the error is this instead:
NI-488: Command requires GPIB Controller to be Controller in Charge.
or
LabVIEW: An input parameter is invalid.
(2,690 Views)
Dear kyle99,
Thank you for contacting National Instruments.
To address your question, it may be necessary for you to include more information such as:
Where do these errors occur? At which VIs?
What are the error numbers?
Why do you think these errors occur?
What do you do differently to receive other errors?
What are you trying to do with your application?
Are you using more than one device?
Are you using VISA writes and reads?
Are you doing File I/O?
Also include anything else you think is pertinent. I've included some links you can search on these topics. Also, you'll find information at ni.com/support if you click on Troubleshooting on the left, then KnowledgeBase, then "Search All Entries" for these errors.
Let me know
if you have any further information or if this resolves your issue.
Thanks again and have a great day!
Chad AE
Applications Engineer - National Instruments
(2,690 Views)
