11-02-2010 01:07 PM
I was wondering if it was possible in Labview to use a property node to change the front panel background color for one iteration and then back to an original color afterwards. I dont think it is possible but would like to know for sure.
Jody
Solved! Go to Solution.
11-02-2010 01:12 PM - edited 11-02-2010 01:13 PM
Yes you can
That's how you change it, you will just have to put some logic to change it back
11-02-2010 03:04 PM
You can get the Pane Property Node directly by right-clicking on the scroll-bar on the Front Panel and Create->Property Node->Pane Color. Useful with multiple Panes. You can also Right-Click the Pane Property Node in for(imstuck)'s example and choose Link To and then select the Pane.
11-03-2010 08:22 AM
Ive tried both methods and get this (broken run arrow):
Property Node 'Property Node': Node not supported in current target.
Jody
11-03-2010 08:36 AM
Update: I got it to work, however, i am using mobile module to program a project, and it doesnt seem to work correctly with mobile applications. However, it works fine on a normal VI. Thanks for your help!
