can we change the shape of controls in Labview Vi
HI,
Is there an option to change the shape of controls in Labview Vi as per the requirement.
Example : can a round LED be reshaped into an arrow ?
Message 1 of 8
(5,591 Views)
The easiest way would be to use a picture ring and create your own. I don't think you can modify the shapes of the controls. Another option might be to place a picture control over a large square boolean with an arrow shaped transparency.
LabVIEW 2012
Message 2 of 8
(5,589 Views)
Did you try a search? This question gets asked a lot. LabVIEW has the ability to customize controls, but to a limit. Did you look in the LabVIEW Help? There was also a recent discussion on this: http://forums.ni.com/t5/LabVIEW/Triangle-or-free-shape-Boolean-control/m-p/1735368/highlight/true#M6...
Message 3 of 8
(5,579 Views)
thanks steve. but i could not find out how to set the transparency for the control.Kindly provide some more info either in steps
Message 4 of 8
(5,553 Views)
One thing you can do is customise the button. In which you have provision to insert the pics or icons for both on and off states and can be used accordingly.
Here are the few steps to follow.
1. right click on control/indicator, reach customised under advanced. the same will be opened in a new vi.
2. go to tools pallete and make both the state (on and off) to transparent.
3. click on the customise button on menu bar.
4. right click on the button and select import pic of same size.
5. follow 3 and 4 for the other state and save.
Now u have your own customised control/Indicator..
LV 8.0, 8.6, 2011,2012,2013 WinXP
Message 5 of 8
(5,549 Views)
Hope am not wrong...
Message 6 of 8
(5,548 Views)
A bit of typing in the search box, and we get:
https://decibel.ni.com/content/docs/DOC-12284
Message 7 of 8
(5,530 Views)
that was really helpful. thanks!!
Message 8 of 8
(5,498 Views)
