can't use Analog to digital express vi
Hi
I have a student edition LabView
I am getting a  signal from servo motor encoder. But when I want to transform it to digital with Analog to digital express vi i can't click the OK button. Does someone know what the problem is?
Boris
(2,506 Views)
Hi Boris,
The Analog to Digital Express VI is a SignalExpress VI.  Are you able to use the other VIs under SignalExpress » Processing » Analog Signals?
Do you have the Full Version or Limited Edition of SignalExpress?  You can check in NI License Manager (Start » Programs » National Instruments » NI License Manager).  Under NI SignalExpress » Development System there should be a green or yellow box next to one of the versions.
Jennifer R.
(2,476 Views)
