can't see USB in VISA resources
I've seen this question, but could not solve the problem.
In the VISA resources I see only LPT1.
I see the device in MAX, but in the VISA I do not see USB resources.
When I copy the name from the MAX I can open the port.
I tried to install multiple versions of VISA but still can not see USB resource..
Message 1 of 13
(4,682 Views)
What sort of USB? Can you attach a screen shot from MAX? What version of LabVIEW and what version of NI-VISA?
Message 2 of 13
(4,669 Views)
just put VISA open and create constant/control.
Not meter if the device is connected when I do it or run it.
Message 3 of 13
(4,625 Views)
That's meaningless. Why can't you answer my questions? No one can help you if you don't provide some useful information about what you are trying to connect to.
Message 4 of 13
(4,616 Views)
Sorry. I don't have internet all the time.
USB 2.0.
windows 7.
VISA 15 and 14.01
LabVIEW 14.
Message 5 of 13
(4,582 Views)
NI 6343 device.
I can't send MAX picture but I can see the device.
Message 6 of 13
(4,579 Views)
It's not a VISA device so you are not supposed to see it with a VISA Resource name control. It is a DAQmx device that you would use with the DAQmx functions. If you had simply mentioned the device name in your first post, your problem would have been solved a long time ago. Why did you think you should be using VISA? Have you actually installed DAQmx?
Message 7 of 13
(4,567 Views)
I am trying to do driver for another device (Agilent) and just wonts to see if the computer is OK becouse I don't have much time for integration.
Message 8 of 13
(4,549 Views)
Then you need to connect the Keysight device. The NI 6343 won't be of any help. What's the model number? Have you searched for an existing driver? How are you going to physically connect the instrument?
Message 9 of 13
(4,539 Views)
The driver is not enough and I'm just write some myself.
It is not complicated, but if there is a problem in the VISA, I would waste time. (In any case I need to give the resource myself)
The connection is USB 2.
Do you think that if I will connect an USB (not MAXDAQ) device I will be able to see USB connection and use the port?
Message 10 of 13
(4,526 Views)
