11-12-2021 01:57 AM
Hi.,,I'm form Indonesia. I have problem with communication data. I want to read the analog data from a Arduino via wireless device ( I use wise 4051-AE device). Where is the error in my program ? Please help.
11-12-2021 02:23 AM
You need to specify an IP address and a port at which the listener is listening. Use an OR function and wire the error out of the TCP read and the Stop button to the inputs and the output to the loop condition terminal so the while loop stops also when there is an error.
