can't insert a 1D array into a 2D array using "insert into array"
Hi all,
I have a very simple problem.
I am trying to insert a 1D array as a column into a 2D array using "insert into array" as shown in image1.
When I try to wire the 1D array into the "new element/subarray" terminal I get the error shown in image2.
according to the help files, I should be able to wire an n-1 dimension array into this the "new element/subarray" terminal. In other words
I should be able to wire a 1D array here.
Can anyone tell me what I'm doing wrong?
Thanks for your help,
(2,646 Views)
Accepted by topic author edCubed
Apparently I had converted the float array into a "spreadsheet string" and I needed to convert it back into an array before sending it to "insert into array".
check out image3 for details.
(2,639 Views)
Hi ed³,
why do you use ArrayToSpreadsheetString and SpreadsheetStringToArray at all?
Why not use NumberToExponentialString? It takes arrays too...
(2,621 Views)
