can't edit enum
I am having an issue with an enum I am using in an X Control. It may be used across multiple X Controls, I'm not sure. Anyways, I closed down the entire project along with LabVIEW so that anything that could be keeping the enum "locked" would be taken out of memory. I then navigated to the control on disk and opened from there. But, as you can see, I can't get the right-click menu for the control. Any time I right-click, it opens the palette. Any idea how to resolve this?
(3,378 Views)
Hello Greg,
I am trying to replicate this scenario, what version of LabVIEW and what operating system are you using?
Have you tried restarting your computer and then access the right-click menu? Also can you try recreating the enum and then see if this issue still occurs.
(3,337 Views)
Accepted by topic author GregFreeman
May be this is pointless but still giving it a try.. Have you tried unlocking it this way? (I suppose you may have)
NitzZ
(Give Kudos to Good Answers, Mark it as a Solution if you Problem is Solved;))
(3,321 Views)
Thanks! This solved the problem. What a mess that was.
(3,294 Views)
