can somebody tell me how I generate this project?
I'm trying to generate the roots of this equation an · xn + an−1 · xn−1 + . . . + a1 · x + a(0) = 0
Message 1 of 13
(4,165 Views)
This is fairly straight-forward, all you need to do is build the equation into a polynomial from an array using ascending power order i.e. x^3 - 2x^2 + 4x -9 = 0 becomes [-9, 4, 2, 1].
Once you have done that feed the array into the "Polynomial Roots.vi" in order to get an array of the roots.
Message 2 of 13
(4,145 Views)
I just started to learn labview and I really don't know how to do that polynom so please help me with a specific i.e !!
Message 3 of 13
(4,133 Views)
press 'ctl + space" and type in "Polynomial root". Either that or in the block diagram right-click the background, then go Mathematics -> Polynomial -> Poly Roots
Message 4 of 13
(4,127 Views)
Coudl you please solve that equation! I really don't get it right now!
Message 5 of 13
(4,126 Views)
Okay ! I am trying right now!
Message 6 of 13
(4,124 Views)
HMMM... I already done that!
Message 7 of 13
(4,119 Views)
You already have an array of coefficients set up within the cluster control.
Now you just need to read the help for the Polynomial Roots VI to learn how to use it and apply that array of coefficients to it.
Message 8 of 13
(4,109 Views)
If you change your output array from a DBL to a Complex double it should work better. To do this, right click the terminal for the array and go Representation -> Complex Double (CDB)
Message 9 of 13
(4,107 Views)
Message 10 of 13
(4,095 Views)
