02-04-2004 07:43 AM
02-04-2004 10:16 AM
02-04-2004 10:38 AM
02-05-2004 11:26 AM
01-25-2007 09:08 AM
I am using the same controller and need to be able to collect, plot, and write data from two channels, one LVDT channel and one load cell channel.
Is the example code on the sensotec site executable? Do I have to create a driver for the controller in addition to using the example to execute this code?
01-26-2007
01:28 PM
- last edited on
05-29-2025
08:20 AM
by
Content Cleaner
Hi Slipfit,
Hmm, I tried to access those examples, but I couldn't register with the Honeywell site to view them. Based on what I have seen before, however, I am guessing that the examples use is the general VISA driver (which applies to Serial, GPIB, USB, etc.) communication. As such, the examples likely send serial commands specific to the Sensotec 2000 (check your manual for such commands) and then you'll receive the corresponding messages in response from the instrument. If this is the case, the only thing you would need to execute these LabVIEW example programs would be the VISA driver itself. This can be downloaded from National Instruments from this website: https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html You should get the most up-to-date version of the VISA driver for your operating system. Hope this helps!
