can i use linux
have LV for linux 5.1 but i would like to use a GPIB board 778032-01 in that enviroment, can GPIB driver support that or what do i have to download?
(2,952 Views)
There is a gpib beta driver for Linux. You can use the AT and PCI interfaces. And there is a separate driver for the ENET interfaces.
Here is the link where you can download the driver for linux, and get more info:
http://www.ni.com/linux/
DiegoF
National Instruments.
(2,952 Views)
In article <50650000000800000030AF0000-1068850981000@exchange.ni.com>,
Check this out if you want open source stuff:
http://linux-gpib.sourceforge.net/
(2,953 Views)
The NI suite I received from NI includes an RPM for GPIB. It is installed in /etc/rc.d/init.d/ and so if installed, should run on boot. If it doesn't then you need to run, in su mode# service gpib start
I have run everything NI successfully on the Mandriva distro.
I have to admit that it took two years of asking to receive the CDROM from NI. 😞
🙂 Peter
🙂 Peter
(2,666 Views)
