can i use C++ to program my labview vi?
i have already create a vi, can i translate it in to c++ code? how?
thanks for help!
(2,811 Views)
Youe subject and message body ask two different questions:
Can you translate vi code to c++ code: No
You can use C++ DLLs in your VI, yes. ...
(2,805 Views)
VIs cannot be translated to sourcecode for other languages. LabVIEW is a dedicated programming language with its own syntax and semantics; therefore it is on the same level as any other language like C/C++, Delphi, C# or VB. The code you will get as the result is a metacode which needs the LV RTE to run. You can compare this to the method as done in .NET.
Norbert
[Edit]: If you think the way like Thomas suggests, you can create a DLL out of LabVIEW-VI by using the Application Builder and use this DLL in a C++-project. This works as well the other way round if you need to include existing c-code in your LV-application.
Message Edited by Norbert B on 08-28-2006 06:09 AM
Norbert
Expert: Geometry
(2,804 Views)
